tie into galv. pipe with PVC
Old 03-20-13, 12:27 PM
Q
Hey guys, any advice on what i would have to do to tie into an old galvanized waterline with new pcv?
Old 03-20-13, 12:29 PM
lawrosa's Avatar
Super Moderator
Received 55 Votes on 48 Posts
You would need access to a threaded part of the galv pipe. Either male or female. Then screw on the proper CPVC adapter.
Your not using PVC are you? Potable water?
Old 03-21-13, 06:46 AM
W
Received 15 Votes on 14 Posts
CPVC to Galvanized
I would suggest female galvanized and male CPVC. A female CPVC on a galvanized male will split if screwed on too tight.
Old 03-21-13, 11:53 AM
Z
Received 84 Votes on 79 Posts
This is assuming you're tying into a supply line. If it's for a drain/vent, you can use a no-hub coupling (a rubber coupling with a metal shield and hose clamps to secure it).
Old 03-21-13, 11:58 AM
lawrosa's Avatar
Super Moderator
this is assuming you're tying into a supply line.
Old 03-22-13, 07:59 PM
Q
i am using pvc for portable water. I know some people are under the impression that code doesnt allow it, but i have already spoken with my city plumbing inspector, a local plumber and the dude working at lowes and they all confirm that its perfectly legal (at least here) to use pvc for COLD water distribution. Also, 90% of the homes in my neighborhood have pvc water lines.
Old 03-22-13, 09:02 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Same here. CPVC is usually only used on the hot side.
Old 03-27-13, 02:31 PM
Q
i was told that pvc can only be used for cold water and drainage and that cpvc is required for hot water but optional for cold as well.
Old 03-27-13, 03:45 PM
lawrosa's Avatar
Super Moderator
IMO I would not use cpvc or pvc.....Expansion issues... There was a class action lawsuit against flo gaurd gold I believe in the past. Would have to look it up. Why have multiple pipe materials??
I would opt for pex, period!
HTML code is On
