InstallingWater Softner.
Old 04-04-13, 08:38 AM
A
Do I just cut the pipe and attach the connector, or should I clean the outside with emery paper first (and/or do something else)?
Thanks all!
Old 04-04-13, 09:16 AM
P
Received 487 Votes on 448 Posts
What type of pipe are you cutting?
Old 04-04-13, 09:21 AM
A
3/4" copper, sorry! Should've mentioned that earlier.
Old 04-04-13, 11:22 PM
A
Probably an extremely silly question, but...
How can I figure out which side of this bypass is incoming and which side is outgoing? Thanks a ton!
Old 04-05-13, 12:13 AM
Received 840 Votes on 787 Posts
We couldn't tell that from the picture. Trace the plumbing back to the water meter and that will be the incoming side.
Old 04-06-13, 05:03 AM
W
Received 16 Votes on 15 Posts
Bypass
Close the center valve and see which side has water when opened.
Old 04-06-13, 07:11 AM
Received 1 Vote on 1 Post
Sidebar question: are those water lines a safe distance from what looks like an electrical panel?
Old 04-06-13, 08:48 AM
A
They're not. It makes absolutely NO sense why they made the house this way.
Old 04-06-13, 12:18 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Amateurplumber, can you site NEC code section for your statement? I don't see a problem. If the pipes break you have a much larger problem and rememeber pure water is not a good conductor.
Old 04-06-13, 12:37 PM
A
I can't state code because I wouldn't really even know where to start. Seems weird that they located them so close to each other, but I suppose unless something awful happened they wouldn't really mix. Unless the water started spraying willy nilly from the pipes heh.
Old 04-06-13, 07:36 PM
A
I have no idea what's going on with my piping.
Ordered and received my softener, asked my buddy to come be an extra hand while I hook it up (he knows a little bit more about plumbing than me since I don't really know much at all :P), and he tells me that this bypass (i'm actually going to cut off the the valves (they're not threaded) and use the pipes to connect to the included bypass) isn't set up to soften all my water, just a few select faucets. Taking a look at it, i realize that i (still) have no idea what this bypass is actually doing. Not sure if he's right, so I figured I'd ask here.
I tried to take some pictures and a video so people could see what I have going on and maybe help me. I really would like to do this myself, and know that, while I'm not nearly the most qualified person, i am capable of doing this, and want to do it, but until I figure this out I'm gonna be at a standstill. I may call a plumber to help me trace the lines, but would really hate to spend anymore money than I already have on this "project." If I go that route I'm going to be out a decent chunk of money and it'll take me a bit to save up for that. :/
Here is the album of pictures I took of the area: album. Here is a video: video.
If anyone could point me in the right direction, that would be amazing! Thanks in advance.
Edit: Err, maybe i should have waited before asking this...I guess i could just shut the valve off and see what it controls. I feel like a fool, lol.
Old 04-06-13, 11:48 PM
If you are attempting the installation of a water softener then you should be able to identify your plumbing lines. You will NOT call a plumber.
Take some time and follow the piping. Start at the water meter or well. Follow from the source to each location. You should know what each pipe going thru the floor connects to. You should see kitchen plumbing, maybe a bathroom, possible lines to the second floor, outside faucets. You should familiarize yourself with all the plumbing and know what each valve controls. You should identify hot and cold lines. It's not hard. Just be a Sherlock.
Those valves on the wall are a good idea in case the softener needs to be removed for service in the future. I would change them to ball valves.
As far as that white line....it looks like some kind of loop. I have no idea what it's supposed to be doing there.
Normally the water softener would not feed outside faucets. In some homes....the cold water side of the kitchen faucet is not on the softener either.
Typical ball valve below.
Old 04-07-13, 01:00 PM
A
Thanks PJ!
I just cant understand what this bypass is actually doing! I figured i'd just put it in using those lines that are already dropped down, and use an external bypass and then eventually solder in some ball valves like you suggested.
So I closed the middle valve, and tested a bunch of faucets. Nothing seems to be happening. If closing that valve does stop water to those faucets, how long would it take to notice reduced/no flow? I thought it was pretty fast. Which means, this bypass isnt doing much at all lol.
Old 04-07-13, 01:47 PM
ray2047's Avatar
Amateurplumber so far I have merged three of your threads. Please don't start additional threads on the same subject. I may delete some of the remaining ones.. If I delete one you really need answers to please add the question to this thread. When you do multiple threads on the same subject it gets confusing.
HTML code is On
