Faucet water is white
Old 06-15-13, 03:40 PM
But at the well house spigot it is very clear/good.
Is it an issue with the water conditioner in the house?
Old 06-15-13, 06:05 PM
F
Received 34 Votes on 26 Posts
Draw a glass of water and then let it sit for a while. Does it then clear up? White water is often nothing more than air bubbles in the water. If you have an under counter carbon filter (might be the same for other filters) and you just changed the filter it is normal to have air in the water. If the latter is the case just run the water for a few minutes and it will clear up.
Old 06-16-13, 06:59 AM
No the water filter was changed a month prior. This is at my elderly parent's house, who don't "computer" :-).
They wonder if the anode rod is shot in the water heater, causing the water to turn white
Old 06-16-13, 07:04 AM
White water
...disregard my last comment about the anode in the water heater, it looks like the water water is on the cold water too. It is definitely still clear on the well head, outside of the house.
Maybe sediment?...drain heater tank?
Still a puzzle as to the cold water
Old 06-16-13, 07:13 AM
Tolyn Ironhand's Avatar
Received 149 Votes on 133 Posts
Did you read Furd's post? If you get a glass of water and let it sit does the white clear up? As he mentioned, many cases it is just air that is dissolved in the water and not really an issue.
Old 06-16-13, 07:35 AM
Yes, read Furd's. No, that did not help, and the filter has not been chnaged recently to cause those bubbles
Old 06-16-13, 08:08 AM
Just to confirm: The white cloudiness stays in a glass of water that you fill up and leave on the counter for 10 min, correct?
Is there a water softener?
Old 06-16-13, 05:22 PM
Correct in the glass.
No water softener.
Tomorrow I will go there in person, vs just hearing the issues.
Old 06-16-13, 05:35 PM
Received 835 Votes on 782 Posts
No.....the heater tank won't affect the cold water side.
HTML code is On
