outdoor shower
Old 02-12-01, 03:16 PM
Guest
what's the easiest way to hook up a shower head and valve to an outdoor faucet? it's going up at work for folks that exercise during day, and needs to look decent for visiting clients (no hose nailed to a wall)--many thanks.
Old 02-12-01, 03:21 PM
Plumber2000's Avatar
Is there not going to be hot water supplied to this valve?
Old 02-12-01, 03:42 PM
Guest
no--simply running off the cold water faucet.
Old 02-12-01, 04:24 PM
Get a hose x 1/2" female brass adaptor, then use cpvc fitting and pipe,
Old 02-12-01, 04:34 PM
Mike Swearingen's Avatar
Cool
Get a double-hose Y to screw onto the outdoor faucet. Turn one side of the Y toward the wall.
Come off that side with a hose bib adapter, and PVC-glue up fittings and 1/2" pvc pipe for a showerhead clamped to the wall with PVC pipe clamps made for the purpose.
Use regular rubber hose washer at Y, and teflon tape (2-3 flat wraps clockwise only) on any other threaded fittings (shower arm and head).
You can use either the little ball valve cutoff on that side of the Y, or install a ball valve with handle in the pipe on the wall.
It will look fine, and you'll still have the other side to connect a hose to, if you need it.
Use a wooden shipping pallet covered with rubber bath or plastic welcome mats for the shower base, if it is on bare ground (mud, grass clippings), or get fancy and build a pressure-treated wood shower stall.
Good Luck!
Old 02-13-01, 06:04 AM
Guest
thanks gentlemen--i'm going to give these a try this weekend (weather permitting)--i'll let you know how it comes out.
HTML code is On
