Tub Faucet Still Leaks After Repair
Closed Thread
Old 07-14-13, 08:10 PM
G
Talking Tub Faucet Still Leaks After Repair
My tub has a Sayco brand 3 handle faucet. The tub faucet was leaking so I went ahead and replaced all three stems with brand new ones and also replaced the seats. However, my faucet is still leaking (cold water only). Does anyone have any idea what the issue could be? The leak is getting progressively worse and I really don't have the funds to hire a plumber so any assistance would be greatly appreciated. Thanks in advance!
Old 07-15-13, 05:05 PM
W
Received 11 Votes on 9 Posts
Hi, Did you put some teflon tape on the seat threads before you installed them?
Woodbutcher
Old 07-24-13, 06:46 PM
G
Hi Woodbutcher - I tried what u suggested since i had not used the Teflon tape on the threads. It still leaks, but I did notice one thing; after i shut off the main water supply outside, water still drips? Any ideas of what could be the issue? Thanks so much for your help!
-Gina
Old 07-24-13, 07:03 PM
lawrosa's Avatar
Super Moderator
Received 55 Votes on 48 Posts
Your sure its leaking? Open the center handle halfway after h/c off... It drains the shower riser... That could be the drip...
Never use teflon on the seats.... Just my opinion....
Old 07-30-13, 05:51 PM
G
Hi Lawrosa - I shut off the main water supply by my water meter outside. I removed all three stems again and noticed that the cold water continues to drip even though the main water supply is off. Now I'm really confused because the cold water drips regardless of the water being shut off and even when the stems and seats are replaced with new ones. Totally confused and frustrated...any ideas?? Thanks in advance!
Closed Thread
HTML code is On
