Toilet Bowl Does Not Hold Water
Bowl fills fine after flush. Tank does not run. Bowl empties of water after 15-20 minutes after flush.
Any ideas?
Any ideas?
The vent that comes out the roof top, is there one above the bathroom? If there is check to make sure it's not plugged up, run a hose down it.
If the vent is fine, then pull the toilet, take it outside, set it up on blocks, fill it with water, if it still leaks out, install a new toilet.
