Installing a washer away from vent stack and main drain
Old 07-31-13, 11:02 AM
P
I want to install a full-size washer in a room next to kitchen. Can I connect the washer drain to the drain of the kitchen sink, or will there be a sizing/capacity/flow issue? And I understand draw vents are illegal in many cases, but I can't get to main vent stack from this room. What are my options for venting? The washer will be against an exterior wall. Can I create some kind of vent to the outdoors in this room? Sorry I think you can see I have a lot to learn.
Thanks for everybody's time!
Old 08-01-13, 04:18 PM
P
Temporarily Suspended
You will definitely have a flow issue.
Old 08-02-13, 08:34 AM
P
Thanks Pulpo. What size drain is required for a full-size washing machine? If I have a laundry tub to drain into first, that should avoid the flow issue, correct?
Old 08-02-13, 07:02 PM
P
You can drain it into a slop sink first. Otherwise, washing machine drains are 2 inches.
HTML code is On
