Kohler Whirlpool On/Off Switch
Old 08-19-13, 12:25 PM
W
I broke the On/Off switch that is mounted on the side of my Kohler Model 1466 Whirlpool. Kohler doesn't offer a replacement. It is a air type (puff) switch that activates the whirlpool motor. I can still use the whirlpool by utilizing the wall mounted on/off switch but I miss the convenience of the tub mounted switch. Any ideas??
Old 08-19-13, 05:24 PM
Received 836 Votes on 783 Posts
Welcome to the forums.
I'm guessing you need the top piece that you press in to activate the power.
I thought I had found it in stock at a place but did not.
The part you need is the 60735. I've seen a listed sub for that part and it's 60785-CP.
You might want to check with these people to see if that substituted part will work for you. It will probably say JETS on it instead of POWER but if it works.... go for it.
Guillen Product Listing for 60735/60785
Old 08-20-13, 05:25 AM
W
Actually, the top piece with the little plunger & o-rings looks like it might be OK. Its the piece that mounts on the tub rim & receives the plunger that got broken & needs replacement.
Old 08-20-13, 07:56 AM
Maybe the JETS and POWER use the same mounting piece ?
Not enough detail in the pictures I've found.
HTML code is On
