Stabilizing Piping
Old 09-09-13, 07:06 AM
Marie B. LePage's Avatar
Question Stabilizing Piping
Hi - new home owner here! I have these two pipes coming down to the utility sink. They connect to the washer. But they are out 2-3 inches parallel to the wall. So whenever they open, they jerk and make noise. What kind of equipment do I need to stabilize them to the wall? Or how else can I fix this problem?
Thanks in advance!
Old 09-09-13, 08:41 AM
G
Received 2 Votes on 2 Posts
I think that I would mount a properly sized block of wood between the wall and the pipes, and then clamp the pipes to the wood with copper pipe supports.
Old 09-09-13, 08:59 AM
Thank you. That makes sense up until a point. The pipes go up and then turn to the right towards the wall (still several inches away from the wall). I feel like if I put a board behind the pipes and clamped the piped onto the board, it wouldn't do much without being connected to the wall itself, right? Can you help me think this through?
Old 09-09-13, 09:05 AM
Gunguy45's Avatar
Super Moderator
Received 4 Votes on 4 Posts
You'll need to attach the board to the wall using Tapcon screws or construction adhesive. Then clamp the pipes to the board.
lawrosa's Avatar
Super Moderator
Received 69 Votes on 61 Posts
As goldstar said attach the wood to the wall first... Use concrete anchors..
Use the cavity type. Drill a hole in the wood and cement with the proper size masonry bit for the cavity anchors you buy..
You will need two washers so the screw/bolt head does not penetrate the wood.
Then use standard copper or plastic pipe clamps to attach the pipe to the wood.
Old 09-09-13, 09:07 AM
How do you attach the wood + tapcon screws to the wall? Are the screws long enough that you just drill through the 1"-2" wood? I'm that much of a newbie that I don't know how I'd do that piece.
Old 09-10-13, 05:24 AM
W
Received 34 Votes on 31 Posts
Bracket
Build wood brackets. Build up the bracket from a treated 2x4 laid flat against the wall plus whatever else you need to build out the bracket to the correct stand-off distance between the pipe and the wall. Make the 2x4 larger than the remaining bracket so you can fasten the 2x4 portion to the wall with Tapcons.
