411 BTUs through 1" CSST pipe?
Old 09-17-13, 10:14 AM
My HVAC guy is installing a new CSST gas line for me. Based on my calculations, the total of all the gas appliances is 411.5 BTUs.
I've calculated the total length of the longest leg to be 70 feet (to the most distant appliance)
He's planning on running a short length of 1" CSST pipe from the meter to the gas manifold (~5 feet), then individual CSST lines to each appliance.
I expressed my concern to the HVAC guy, but he told me that a 1" pipe can handle that amount of gas when the length is short. But, I thought you based the capacity of the pipe on the total length of the longest leg.
Is CSST somehow different? Does the manifold change things (all should be open)?
Am I right to be concerned that a 1" pipe can't handle that amount of gas?
As a test, I plan to turn all the appliances on at the same time and see if anything chokes/stalls/flames out (gonna get warm for a while).
Old 09-17-13, 10:29 AM
lawrosa's Avatar
Super Moderator
Received 10 Votes on 8 Posts
No, not as far as I know.... The rule is from the code books is once in the ft column you must stay in that column. Based on your 70 ft you must use that column from the chart. 1" will only support 240K BTU...
According to the chart you must use 1 1/4" . That supports 490k btu
I would be.. Have him show you in the code where it says use of manifolds changes anything.
Is it piped? Why would you let him pipe it if its wrong???
There may be your issue. He most likely is not a licenced plumber and working under someones license... Get a signed document from the plumber he is working under that this is OK. I doubt they will produce it.
HTML code is On
