valve is missing handle and in want to install a RO system
Old 09-26-13, 11:27 AM
N
so i just looked at my cold water valve in my kitchen and it doesnt have a handle.
When i shut off the cold water it starts to leak from where the circular handle would screw in, and the further i twist the more water shoots out.
is there something i can buy to clog the hole? or anything i can do?
RO is reverse osmosis
Old 09-26-13, 11:37 AM
lawrosa's Avatar
Super Moderator
Received 59 Votes on 51 Posts
Hi...welcome..
You can tighten the packing nut to stop the leaking. The valve will be harder to turn maybe..You usually could buy a similar valve and use the handle from that one...Unless you chewed up the splines on the existing valve....
HTML code is On
