compression fitting alternative
Old 09-26-13, 11:06 PM
I just moved into a new construction home and less than one month in we had a plastic pipe burst out of the brass compression fitting. Thank god we were home and caught it early before any damage was done. Now I have a great fear about it happening again. Is there anything I can do for added security on these fittings or is there a better and more reliable alternative I should invest in?
Old 09-27-13, 03:12 AM
chandler's Avatar
Received 2 Votes on 2 Posts
What sort of pipe was it? Refrigerator line, main supply line, dishwasher line, sink line, toilet line?? Was it clear, white, red, blue or gray?
Old 09-27-13, 04:54 AM
its a gray pipe that runs to the bathroom sink. it just burst right out of the fitting.
Old 09-27-13, 05:40 AM
The builder cheap out. Remove and toss all the supply's on all the fixtures and replace them with Stainless steel braded lines.
Old 09-27-13, 06:18 AM
I tried attaching a picture earlier, so here you go just to clarify what I'm talking about.
Old 09-27-13, 11:05 AM
Received 345 Votes on 323 Posts
Those are splice fittings in the line. I'm guessing this pic is just to show us the type of pipe and fittings.... it's not behind the sink.
Did they run this same gray pipe right to the sink with no valves ?
Old 09-27-13, 01:05 PM
chandler's Avatar
Take the compression fittings off and see if there is a metal ferrule on the pipe. If so, that is the problem. You cannot use a metal ferrule on plastic pipe. You will need to cut back the pipe below the current crimping and install plastic/nylon ferrules and reassemble it all. You should be fine at that point.
Old 09-27-13, 02:47 PM
GregH's Avatar
Super Moderator
Received 9 Votes on 9 Posts
In addition to nylon ferrules you need to use a brass bushing inserted into the pipe otherwise the ferrule has nothing to compress against and can come apart under pressure.
Image courtesy of wattsdotcom
HTML code is On
