Outside faucet leaking in pipe behind brick wall
Old 10-03-13, 11:54 AM
An outside faucet pipe on front porch is leaking behind brick wall somewhere.
The plumbing is between sheet rocked bedroom and exterior brick wall.
The water is seeping out under brick onto the porch, but is not leaking into the bedroom. What is best way to attack this? From the Sheetrock side, or thru the brick?... If from the brick side, how much of an area around the opening should I remove, and how to go about it?
Thanks.
Old 10-03-13, 05:29 PM
From the sheetrock side.
A whole lot easer to repair then the brick.
HTML code is On
