expansion tank
Old 10-07-13, 06:40 PM
P
expansion tank
I think my expansion tank has gone bad AGAIN! Its only about 3 years old. First one the bladder went and now I notice everytime I use water the pump kicks on. Checked the air and its only at like 10psi. I tried putting air in it as it needs like 40 psi but it wouldnt raise the pressure at all but I was using a small air pump. So how could I check it to see if the bladder is fine and could hard water be causing the tank to fail?
Old 10-08-13, 06:17 AM
Z
Received 89 Votes on 84 Posts
Did you turn off the water and drain the pressure out of the system before trying to add air? I'm not sure that's really your problem, but I know it's suggested to have the system depressurized when you're adding/checking the air.
Is this a well pressure tank or a small one mounted near your water heater?
Old 10-08-13, 12:28 PM
P
Its a well pressure tank. I just drained it and added 38 psi.
Old 10-08-13, 02:12 PM
Z
As long as it holds that charge for a while, you should be good.
For future reference http://www.doityourself.com/forum/we...ml#post1453545
This post tells you how to repressurize your tank. It mentions setting it for 27/28psi... but that sounds low to me. Someone who knows this better than me should be around shortly to confirm.
Old 10-08-13, 03:53 PM
P
Yup thats how I did it and it seems good for now. Thanx!!!
Old 10-08-13, 03:57 PM
lawrosa's Avatar
Super Moderator
Received 59 Votes on 51 Posts
check the psi once a yr. It will lose some pressure yearly. Low psi damages the bladder as well as short cycling the pump which will shorten its life...
HTML code is On
