Large water tank
Old 10-15-13, 03:19 PM
Large water tank
I would like to know the step by step process on how to make a clay or ceramic water tank.
I am going to buy Bentonite clay to make the tank. The total capacity will be 50 gallons.
So I need to know what other ingredients I need and how to go about it. In what percentages. I guess I will need the clay and sand and water.
Please give me the process.
Old 10-15-13, 05:09 PM
Main question is why in the world would you want to do that?
Old 10-15-13, 05:53 PM
Received 913 Votes on 853 Posts
I had heard of Bentonite clay but wasn't aware it was used in pottery. From the description I was reading that type of clay is considered a plastic type expanding clay with exceptional medicinal uses.
It would appear that you could add a small amount of Bentonite clay to another type of clay for pottery use.
Since this isn't my line of work I can't answer your question directly but I'm thinking that if you plan on using a home made clay project as a water tank that it will need to be sealed and fired in a kiln.
HTML code is On
