Frozen bathroom shutoff valves -
Old 10-17-13, 07:24 AM
GM, maclorjoe here -
Just wondering if anyone has an idea's as to freeing up bathroom hot and cold shutoff values that are frozen in the open position. I need to replace both faucets on the double bowl sink and have tried using WD-40, the valves on the cold side appear to be working now, but both values on the hot side are not. I want to avoid using the main in the house if at all possible. Thank You -
Old 10-17-13, 07:42 AM
lawrosa's Avatar
Super Moderator
Received 59 Votes on 51 Posts
loosen the packing nut some. You may get a little water drip. Sometimes you need to grab the handles in a way with a channel locks to break that first turn. Once that is done you can normally turn by hand the rest of the way...
Then just snug packing nut when done.
Old 10-17-13, 07:48 AM
lawrosa's Avatar
Super Moderator
Watch this... Its the only vid I can find. Its for demonstration only and in no means has anything to do with the company...I am in no way affiliated...
http://www.youtube.com/watch?feature=player_embedded&v=yDRXyGUtrf4#t=46
Old 10-17-13, 08:55 AM
Thank you for the video! Will try this later today!
HTML code is On
