Flexible supply line at softener - Snakebite fittings.
Old 11-07-13, 03:58 PM
R
I want to install a new water softener. I like to do it with flexible supply lines. I can either solder in threaded fittings or I was thinking of using those push fittings that go by the brand name snakebite.....
Would that be a proper installation? Are they reliable? Any tips about using flexible supply lines with a softener? Or should it be all soldered connections even at the softeners bypass valve?
Old 11-07-13, 04:20 PM
Properly sized Pex or flex lines will work fine if you use the right fittings.
No issues with using Shark Bites.
There's 0 reasons to use soldered lines.
HTML code is On
