meter location
I will be running a 2" HDPE line for about 600 feet to my home from the connection to a 6" main. I am limited to a 3/4" meter. Regarding pressure loss, does it make any difference where the meter is located on the 2" line?
Since you will probably running 3/4" pipe in the house it would seem to me to keep the meter as close as possible to the house. In my opinion....just inside the house would be ideal.
Do they read the meter electronically? If so, I would do as PJ says, and install it as close to or inside the house as possible. Necking it down too early may be counterproductive, don't know for sure. Mike will chime in with his idea, I'm sure.
