Can san. tees be used for venting?
Old 02-25-01, 10:57 AM
Guest
Question
I need to vent a horizontal dwv branch. Can I use a san tee to connect the vent to the horz. branch? For some reason I thought that san tees should only be used vertically and that a horizontal setup would go against code. Though the hardware store only sells sanitary tees and wyes but no vent tee.
Thanks!
Old 02-25-01, 11:04 AM
Plumber2000's Avatar
Received 2 Upvotes on 2 Posts
Yes you can vent horizontal drain into a vertical santee vent, providing the vent is only used for the vent.
Old 02-25-01, 01:25 PM
Guest
Thanks Plumber 2000!
Just to double check... The following set-up is fine?....
Old 02-25-01, 02:06 PM
That will work.
