exposed sewer pipe
Old 12-03-13, 05:12 AM
H
exposed sewer pipe
The house is in Colorado. The house was built in the 50's. The sewer line comes out of the house 36" above the ground, runs horizontal along the house 48", then runs vertical where it enters the ground on its way to the septic tank. The existing pipe is 3" PVC. Is it OK to use ABS or PVC where it is exposed to sunlight? If not, what pipe should be used?
Old 12-03-13, 05:29 AM
lawrosa's Avatar
Super Moderator
Received 55 Votes on 48 Posts
I find no issues with PVC use outdoors.
As a matter of fact some of the pool plumbing I have worked on ( pvc at the filter) have no detrimental effects of uv light. And some installations were 25 yrs plus being out in the elements. The cold weather here in the east I believe causes more damage making the pipe brittle in freezing temps..
Although I would probably paint the pipe to give it added protection..
I would not use ABS outdoors...
Old 12-03-13, 06:54 AM
Is PVC and CPVC pipe UV resistant? | US Plastic Corporation
It would be interesting to see a picture of this.
I'd be more concerned with possible impact damage.
Old 12-09-13, 12:19 PM
H
Here is the picture
Here is the picture requested. It is cold out there.
HTML code is On
