gas pipe sizing for small commercial build out
Old 12-03-13, 08:25 AM
I would like to attempt to run a new gas line to a commercial suite that I just leased and need some help determining the size of my gas line.
I have 3 loads at the end of my system. 2 x 80,000 Btu heating units and 1 x 40,000 Btu water heater.
The gas meter is at the far end of the building. I have to run up vertically from the meter to the roof, across the roof, and then down into my unit before I split to the 3 loads. All in all, I am figuring the distance from the meter to my furthest appliance (the water heater) is about 230 feet. 6 elbows would be needed to get to the water heater.
My heating units call for a minimum of 5 inches of water column at the inlet to fire correctly.
The gas company delivers 6 inches of water column to the meter.
Any help would be greatly appreciated.
Thanks!
jds
Old 12-03-13, 09:59 AM
lawrosa's Avatar
Super Moderator
Received 55 Votes on 48 Posts
Your looking at 1 1/4" pipe to supply your 200k btu... Thats a lot of black pipe...
Possibly you can read what the meter plate says for us? Possibly you can ask the gas company to increase the pressure so you can run smaller pipe?
If commercial it may be higher pressure already...
Permits are being taken out right?
HTML code is On
