Sweating copper pipe connected to PEX
Old 12-18-13, 09:59 PM
rdn2113's Avatar
I want to sweat a threaded fitting on the end of a copper stub out pipe that is connected to PEX inside the wall. The stub pipe is about 4 to 6 inches in length.
Is this sufficient length to sweat the fitting without damaging the PEX?
Thanks!
Old 12-19-13, 04:03 AM
Norm201's Avatar
Received 174 Votes on 158 Posts
Wrap a wet rag around the far end of the stub. You should be OK.
Old 12-19-13, 05:06 AM
If your just installing a stop valve, why not just use a compression?
Old 12-19-13, 06:48 AM
P
Received 478 Votes on 439 Posts
PEX is so easy to work with I usually cut the PEX loose so there is no worry about the heat and just connect it back when the other plumbing has cooled.
Old 12-19-13, 10:18 AM
rdn2113's Avatar
I would have detached the PEX initially but it's behind a finished wall and I don't want to cut the wall open. And I'm not a big fan of compression fittings.
I've seen the wet rag suggestion elsewhere so that's what I'll do.
Thank you all!
HTML code is On
