Soldering question - temp barrier
Old 12-19-13, 05:25 AM
Z
When soldering I always fear I am heating up adjacent joints, I worry that they may come loose and leak.
Should I be wrapping adjacent joints with a wet rag? And if so, how close between joints would it be a good idea to create a temperature barrier?
Old 12-19-13, 06:06 AM
Norm201's Avatar
Received 174 Votes on 158 Posts
If the joints are within 5 to 6 inches then yes, I usually wrap with a wet rag. Never had a failure as yet.
Old 12-19-13, 05:23 PM
Z
Received 10 Votes on 10 Posts
I guess the pros will say Im doing something wrong if I have joints within 3-4 inches of each other, but that is the case.
I used a wet rag also at those joints and never had a problem
Old 12-20-13, 05:45 AM
Norm201's Avatar
Never heard that having joints close together is not right. I've seen joints soldered right next to each other.
Old 12-20-13, 06:19 AM
Gunguy45's Avatar
Super Moderator
Received 3 Votes on 3 Posts
There can be problems with joints close together...if you aren't using the right torch. A typical homeowner will use a propane torch which doesn't heat the joints as quickly and can allow heat to get to nearby connections.
Better to use MAPP or acetylene.
Old 12-20-13, 11:21 AM
Z
Yes I got the advice to use MAPP on this forum. Best advice I ever got. I could not believe what a difference it makes and I was in fact able to heat the joints quickly.
HTML code is On
