bathroom sink drain
Old 02-27-01, 10:37 AM
curlie
I have just installed a new sink and vanity top. The tailpiece from the sink drain is in a vertical position, as is the ABS plastic drain pipr. I formerly reached the drain by using two j-bends, but those will not reach the drain now. They are about 1 1/2 in. from the drain when fully extended (you know how you can rotate them around). Any suggestions?
Old 02-27-01, 10:45 AM
Mike Swearingen's Avatar
Received 1 Upvote on 1 Post
Cool
I'm not a plumber, but I would just use one p-trp, extend pipe over above the vertical drain and 90 down to it.
Good Luck!
