Water dripping on pump
Old 12-23-13, 06:52 AM
Z
I have some condensate lines going directly into my sump pit. It drips directly on top of the pump. I would assume that is OK, but I wanted to ask anyway.... is there any harm in having water drip on top of a pumps housing?
Old 12-23-13, 07:19 AM
lawrosa's Avatar
Super Moderator
Received 55 Votes on 48 Posts
condensate is corrosive... Is the pump plastic or metal??
I probably would not worry about it...
Old 12-23-13, 12:29 PM
P
Received 487 Votes on 448 Posts
I would not want condensate dripping on a pump. It's probably OK if it's a submersible pump but otherwise I'd try to keep it dry.
Old 12-23-13, 01:05 PM
lawrosa's Avatar
Super Moderator
I dont see a difference ... Does the pit fill with condensate that the pump is submerged in it? Or is it diluted by ground water?
Old 12-23-13, 04:41 PM
Z
Maybe I shouldny just say condesate... it has condensate from the furnace dripping on it and even water from a laundry tub and a water softing unit.... in any case, water is touching the plastic housing. THe base is metal.
Old 12-24-13, 05:31 AM
P
If it's a short, fat pump down in the sump then it's probably a submersible and water will not hurt it. It's designed to be totally submerged. If there is a pump at the bottom, a long shaft or tube coming up then the motor up in the air then it's a pedestal pump and you should do your best to keep the motor dry.
submersible pump:
pedestal (not submersible pump):
HTML code is On
