Using Old Material
Old 12-26-13, 03:47 AM
R
Using Old Material
I have some unused pipe and fittings that are 15-20 years old.... is there any harm introducing them into my plumbing system at this stage of the game?
Old 12-26-13, 04:37 AM
Norm201's Avatar
Received 174 Votes on 158 Posts
Are they copper or iron? Are they used or new?
If new copper, go for it.
Used iron...NO.
Used copper...??? depends.
Old 12-26-13, 05:13 AM
R
In this case, its copper pipe thats never been used. And its brass fittings that would be applied to copper pipe thats never been used.
Old 12-26-13, 05:47 AM
Norm201's Avatar
In that case I see no reason why you can't use them. What type of copper is it (type k,L, or m)?
Type L
Coming in the same sizes as K, Type L copper tubing is used chiefly for medium-pressure interior plumbing, and for steam and hot-water heating systems. It should not be used outdoors in underground connections. The wall thickness of Type L is about half way between the wall thicknesses of Types K and M. In 3/4" size, its bursting pressure is about 4,000 pounds per square inch.
Type M
Available in sizes from 2 1/2" to 12", Type M is used where water conditions are normal for low-pressure plumbing. It is also used in low-pressure steam and hot-water heating systems. Its bursting pressure is 3,000 pounds per square inch in the 3/4" size.
As a general rule, use Type K whenever possible, Type L only when necessary, and Type M rarely. Type M might be used, for example, in a place where piping will not be subjected to considerable pressure and a lighter tubing is necessary.
The above was lifted from:
Mike, The Home Depot Answer Man [h=3]Source:[/h] Plumbing. Learn how to do the plumbing yourself and save money
HTML code is On
