Plumbers putty or gasket that came with sink strainer?
Old 12-29-13, 03:53 PM
I am installing a new sink. Most of what I read says to use plumbers putty around the bottom of the sink strainer between the strainer and sink. My sink strainers came with an almost foam like gasket for on top (for underneath there is a rubber gasket). My question is, do I just use that foam gasket, remove that and use plumbers putty or use the gasket and putty?
Old 12-29-13, 03:55 PM
lawrosa's Avatar
Super Moderator
Received 55 Votes on 48 Posts
Use the gasket only, or putty only... Not both...
You sure thats what its for?
I toss them and use putty.. But have only seen them with bath sinks.....
Old 12-29-13, 05:54 PM
W
Received 11 Votes on 9 Posts
Hi, I read the directions on a tub of plumbers putty and it stated not to be used on cultured marble.
We used tub /tile caulk.
Woodbutcher
Old 12-29-13, 06:03 PM
You sure that's not the foam that holds the stopper in place until the cables installed in the new style quick connect faucets?
http://www.americanstandard-us.com/a...Parts_2149.pdf
If so once the cables connected it gets removed and tossed out.
Old 12-29-13, 09:27 PM
I don't think it has anything to do with the faucet.
The foam probably forms a decent seal. I would think the plumbers putty would form a better seal. Unfortunately, the directions are extremely vague.
Old 12-30-13, 05:19 AM
Norm201's Avatar
Received 175 Votes on 159 Posts
I'm a believer in plumbers putty but the new prevailing practice is to use silicon caulk. And yes, plumbers putty is not recommended for marble or granite as the oils in the putty will stain the stone.
Old 12-30-13, 06:46 AM
lawrosa's Avatar
Super Moderator
Not just stains but causes hairline cracks too...
Old 12-30-13, 08:01 AM
Not sure how granite/marble comes into this. I am talking about where the strainer attaches to the sink. Both are stainless steel.
Old 12-30-13, 08:05 AM
I did find the install guide online and it says to use plumbers putty. The foam ring is for under the sink.
The disposal I bought (GE) says not to use plumbers putty on a stainless steel sink install (putty to be used on other sinks) and to use a rubber gasket it came with.
Old 12-30-13, 12:57 PM
F
Received 34 Votes on 26 Posts
Standard plumber's putty is for porcelain and metal sinks or for tile and laminate counters. It WILL cause problems with either natural or man-made stone products. However, they also make "stainless" plumber's putty for these other materials. Problem is the stainless material costs five or six times as much as the regular and both products come in a tub that will last an average DIYer well into their third lifetime.
HTML code is On
