shutting water off to house
Old 01-01-14, 04:03 PM
What provisions should be made if you had to shut off water to the house for a few days?
Im most wondering about the water heater.....
Old 01-01-14, 04:12 PM
P
Temporarily Suspended
The water heater will probably be OK. What kind of heating is in the house? Do you plan to drain the pipes, to complete the work? If so, you don't have to worry about pipes freezing.
Old 01-01-14, 04:23 PM
lawrosa's Avatar
Super Moderator
Received 55 Votes on 48 Posts
I leave the water heater if just a weekend trip... If longer I put on vac mode if gas..
Water line i simply turn off the main when I leave....
If electric I would probably kill power to it while I was gone...
Old 01-01-14, 04:40 PM
Thanks. Its gas heat. Gas water heater.
Just to confirm, I don't have to shut the cold line off at the water heater or turn off the pilot (or gas totally for that matter)?
Old 01-01-14, 05:10 PM
D
Why are you shutting off the water?
Old 01-01-14, 07:04 PM
Z
Received 84 Votes on 79 Posts
For a week, no, you don't have to do anything. Shutting off the water main makes sense if you're going away during the winter just in case there happens to be a power outage and freeze or a washer pipe bursts.
As others have said, I would put the gas water heater on vacation mode (just to save on gas) or turn off the electric water heater for the same reason.
HTML code is On
