OK to bend soft copper with an electrical conduit bender?
Old 01-03-14, 08:51 AM
T
Just wondering, and maybe someone has heard of people trying to do this. The hardware store sells a nice 3/4" electrical pipe bender. I was wondering if it is ok to use this to bend soft copper. I'm just trying to get a nice gradual 90 degree bend without kinks.
Old 01-03-14, 09:28 AM
Tolyn Ironhand's Avatar
Received 148 Votes on 132 Posts
Bending it over any round object would work. Conduit bender would be my first choice but I am quite familiar with that tool.
Old 01-03-14, 09:30 AM
lawrosa's Avatar
Super Moderator
Received 55 Votes on 48 Posts
Exactly what copper are you bending???
Old 01-03-14, 10:52 AM
T
I'm going to use Type L soft copper. Should I use a different type?
Old 01-03-14, 10:54 AM
lawrosa's Avatar
Super Moderator
I assume its in a roll? Yes use a bender as you propose...
Mueller Streamline Soft Copper Tubing - Type L - 1/2" x 60' - Amazon.com
Old 01-09-14, 09:10 AM
T
Is it ok to just bend the soft copper (Type L soft copper) by hand without using a bender? Because of space constraints under the house, I cannot bend the copper with a conduit bender.
Also, I've heard of people using sand, rope, and other material inside of the copper tube to prevent it from kinking when they bend hard copper. Is this necessary when bending soft copper?
Old 01-09-14, 09:13 AM
lawrosa's Avatar
Super Moderator
Is it on a roll????? If so bend it by hand... If you need a sharper bend you need to use a bender...
If issues with space pre bend then install...
Old 01-09-14, 10:09 AM
Why not use a spring bender?
spring benders for tubing - Bing Images
Old 01-10-14, 12:49 AM
F
Received 34 Votes on 26 Posts
Unscrew the handle from the conduit bender and use just the head.
HTML code is On
