Cut into Existing Dry Vent
Old 01-04-14, 12:02 PM
F
Hello,
I'm putting a bathroom in my basement and just looking for clarification. I am tying my basement dry vent into my 3" stack. When I cut into the stack i had some, not a lot, but some water come out when I made my first cut. My septic waste line is 3' down from cut. I have a sink that drains into the stack from 2' away and I made my cut 11" from the top of the sink drain fitting. I am planning on setting my 3x3x1 1/2 wye 6" above the top of the sink drain pipe. After seeing the water I am wondering if it needs to go higher? Or if the bit of water is common?
Cheers,
Fletcher
Old 01-04-14, 12:14 PM
lawrosa's Avatar
Super Moderator
Received 55 Votes on 48 Posts
Yes needs to be 36" above the flood plain of the sink... Thats code in the states here in USA...
What drains into the stack from above? If anything then you cant tie in as that is a wet vent...
But codes may be different where you live...
Old 01-04-14, 01:01 PM
F
Picture added
Here's a picture, easier to see that way. Main waste line runs below floor following stud direction. Was going to tie the new dry vent into the stack 6" above the sink pipe. Were you saying I should be then 36" above the sinks drain tie in my dry? Code for you would work fun for me up here
Nothing drains into this stack aside from the sink shown. It goes through the roof.
Thanks for your help
Old 01-04-14, 04:09 PM
lawrosa's Avatar
Super Moderator
36" above the flood plane which is the top of the sink itself...
But may I ask what that dry vent is for? I assume the sink is using the stack as a vent and the dry vent is for the other fixtures? ( Tub...Toilet...?)
HTML code is On
