Saddle Valve Leaking
Old 01-06-14, 07:52 AM
R
Hi everyone,
I recently installed a new humidifier in place of an old broken one. When I turned the saddle valve from the water supply I noticed that it was leaking pretty badly.
Im completely novice when it comes to plumbing....can someone please tell me this is an easy fix? If not, can you lie.......or at least point me in the right direction to repair this?
Thanks!
Rob
Old 01-06-14, 08:22 AM
Those things leak or clog up at some point and are not even allowed by code in some places.
Can you post a picture?
Really need to cut the pipe and install a real stop. (shutoff)
Old 01-06-14, 08:54 AM
R
Heres a pic of it. What about a sharkbite fitting?
Old 01-06-14, 01:05 PM
P
Received 3 Votes on 3 Posts
where was it leaking from? The picture does not show any drops. you may be able to tighten down the nut that the stem/shaft goes through.
Old 01-06-14, 01:13 PM
Gunguy45's Avatar
Super Moderator
As close as it is to the soldered joint...not sure a SB would seal.
Old 01-06-14, 01:16 PM
R
Wow...I really am a lot more novice than I thought. I tightened the nut where the stem went through and no more leaking. Thanks for your help!
HTML code is On
