Need 2" Pipe Insulation
Old 01-06-14, 10:19 AM
R
Im looking for that foam pipe insulation but for a 2" pipe (PVC) .... theres a trade name of Armaflex but I cant find what I need.
Do they sell that foam insulation in 2"?
What is the ID size I need for a 2" PVC?
Old 01-06-14, 10:59 AM
chandler's Avatar
Received 4 Votes on 4 Posts
Curious as to why you need such large insulation. The OD of the pipe and fittings would be 2 1/4 to 2 1/2"
Old 01-06-14, 11:08 AM
R
I dont think that stuff is purchased by OD. It comes in at least 1/2", 3/4" and 1" thickness.
Not really relevant but it would be used on a 2" pvc intake and exhaust of a condensing furnace.
The trade name is Armaflex or Armacell.
Old 01-06-14, 11:16 AM
chandler's Avatar
Armaflex 2 1/2" x48' long $169 at big orange.
Old 01-06-14, 11:26 AM
Gunguy45's Avatar
Super Moderator
Received 3 Votes on 3 Posts
I swear I saw something in a thread about manufacturers recommending NOT insulating those lines? Don't hold me to that though.
Oops...maybe I mis-remembered.
Here's an excerpt from a manufacturers manual I grabbed from another site. Don't know which manufacturer.
Vent Freezing Protection
When the vent pipe is exposed to temperatures
below freezing, i.e., when it passes through
unheated spaces, chimneys, etc., the pipe
must be insulated with 1/2 inch thick sponge
rubber insulation, Armafl ex-type insulation or
equivalent. Insulating pipe is important to avoid
condensate icing.
For extremely cold climates or for conditions of
short furnace cycles (i.e. set back thermostat
conditions) the last three feet of vent pipe can be
reduced one nominal pipe size provided that the
total vent length is at least 15 feet in length and
the vent is sized in accordance with the venting
requirements (Table 5) before this reduction is
applied. (Example: 3 to 2-1/2 or 2 to 1-1/2)
Smaller vent pipes are less susceptible to freezing,
but must not be excessively restrictive.
Any HVAC supply house should be have or be able to get what you need....if they sell to non-Pros.
Old 01-06-14, 12:14 PM
lawrosa's Avatar
Super Moderator
Received 55 Votes on 48 Posts
Im sure thats for a whole carton....
Old 01-06-14, 01:07 PM
R
Those cartons at Evil Orange are all I can find too... theres no single lengths on their website.
Old 01-06-14, 01:10 PM
Gunguy45's Avatar
Super Moderator
What about an HVAC store or Grainger?
Old 01-06-14, 01:55 PM
lawrosa's Avatar
Super Moderator
Call your local Ferguson.........
Locations Finder
Old 01-06-14, 02:22 PM
R
You guys are right, going to have to find an HVAC supplier... we don't have any of the ones you suggested around here, but some of the contractors have parts dept's... maybe that's where I have to go.
Its Armaflex APT20034 with a 2" IPS (not sure what IPS is).
Its only sold by the case online though.
Have any of you ever seen this under a different brand name? Maybe that's the route I need to take or find an alternate material.....
Old 01-06-14, 02:40 PM
Gunguy45's Avatar
Super Moderator
I think Graingers brand was Thermoflex...looked to be the same kind of stuff.
Old 01-06-14, 04:03 PM
R
Ive realized that I probably even use that pre-formed stuff. The pipe exits at the sill plate of my basement. The pipe is perpendicular to the sill so I couldn't wrap that insulation around it. Also the ells are right there too, they need to be insulated, I probably need something else.... perhaps a tape.
What other insulation material can I use here?
Old 01-06-14, 04:09 PM
lawrosa's Avatar
Super Moderator
3" pvc pipe has an OD of 3.5"
Find what you need with an ID of at least that...
There is no R value to that stuff really... May be better with a better solution if you really have a freezing condensate issue....
Old 01-06-14, 04:45 PM
R
Lawrosa - The pvc is 2" actually, but like I said, the preformed stuff wont work cause I cant get it totally around the pipe.... (just now realizing this). The portion I can get it around are the elbows, so that wont work out so well either.
I have some rolled pipe wrap that has a foil side and a fiberglass side. I could probably get that to wrap around but then I am worried about the fiberglass/condensation moisture issue that would probably occur.
Old 01-06-14, 05:04 PM
lawrosa's Avatar
Super Moderator
Why not? There is a split in it... And for the elbows you tape a small split piece to the inside of the ell weher it does not wrap and tape it..
You can get premolded stuff too...
Buy Proto PVC - Zeston PVC - Speedline PVC Fittings 90 45 Degree Elbows Tees Victaulic Flange Coupling Covers Mechanical Groove Sump
Nominal Pipe Size to Outside Diameter of a Pipe Chart - Buy Insulation Products
Fiberglass Pipe Insulation (2" Thickness)
PVC 90 Deg Elbow Cover
HTML code is On
