Drains slow ? Cant find pipe for snake?
Old 01-06-14, 10:30 PM
biketrax's Avatar
Received 1 Vote on 1 Post
toilets gurgle and slowing drains in neighbors house. I want to snake main drain valve that I usually am able to find in most homes but not here?
city sewer hookup I am stumped could it be outside(buried) ?? already looked in and out?? I do allot of work and am very familiar with this house?
any help thanks
Old 01-07-14, 06:06 AM
biketrax's Avatar
I am trying to locate the Y-Joint in the main house drainage. The one that makes it easy putting the snake though.
thanks
Old 01-07-14, 06:26 AM
Z
Received 84 Votes on 79 Posts
By code there should be a main cleanout, either just before the main exits the house or if that's an inaccessible space, at the end of the main lateral. But as I'm sure you've seen, just because it should be there doesn't mean it is.
There could be a cleanout outside, but in colder climates those are sometimes not used, and could as easily have been buried over the years of landscaping.
Is the house on a basement/crawlspace or slab?
I've heard of plumbers removing a toilet to get to the main stack... Others may have better/easier suggestions.
-Mike
Old 01-07-14, 06:33 AM
lawrosa's Avatar
Super Moderator
Received 55 Votes on 48 Posts
Yes if no cleanout anywhere pulling the toilet is the best option...
Old 01-07-14, 07:23 AM
biketrax's Avatar
Zorfdt 2 story House is on the side of a hill on a slab. One last pile of junk to move to possibly see if anything is behind it there in garage. Basement toilet and garage are in corner of house closest to street. Otherwise will consider that toilet removal. This has been starting since the cold weather been upon us?
HTML code is On
