When hot and cold lines cross... which one on top?
Old 01-14-14, 06:41 PM
T
What to do when you have to costs a hot and cold line? Which one goes on top? Does it even matter? The pros do this so much, there must be some general rule of thumb. Or maybe superstition?
Old 01-15-14, 06:31 AM
P
Received 477 Votes on 438 Posts
There is no rule that I am aware of. Usually the routing of the lines will make one work better on top but when in doubt I put the hot line on top because heat rises. There's no real logic or much of a reason but it's my tie breaker for which goes on top.
Old 01-15-14, 08:35 PM
F
Received 34 Votes on 26 Posts
I would add that when two pipes cross make certain that they cannot rub on each other.
HTML code is On
