How far from wall to stub out the water line for toilet?
Old 01-15-14, 03:10 AM
T
How far out from wall do you stub out the water line that eventually connects to the toilet tank?
I stubbed out our 1/2" copper line so that it is almost directly under the inlet hole to the toilet tank. I connected a flexible braided steel hose to connect the 1/2" water line to the tank, but there is a very sharp kink in the hose line that I cannot get rid of, so I was thinking about shortening the 1/2" copper water line.
Old 01-15-14, 06:14 AM
P
Received 481 Votes on 442 Posts
I've honestly never bothered to measure how far from the wall I put toilet feed lines. How high above the floor is your shutoff valve? If you can't get the line to connect without a sharp bend I'm guessing it's quite high. In every position I've ever put the water line, connecting to the toilet has not been a problem with a flexible line. The flexible lines are available in different lengths. With the valve directly under the tank connect point a short 10-12" should work with a bit of a U shaped bend. With 20" lines I sometimes have to make a loop to use up the extra length.
HTML code is On
