Shower trap with union above finished ceiling
Old 01-16-14, 07:01 PM
P
Hello,
I had to do some work on my ceiling, below my 2nd story bathroom, and I happened to get a look at the shower trap. It's a 2" pvc p-trap with a union:
Would it be better to have a solvent welded p-trap, to avoid the threaded connection? Or am I making work for myself?
Thanks!
Old 01-17-14, 04:09 AM
Norm201's Avatar
Received 174 Votes on 158 Posts
If it don't leak, leave it!
Old 01-17-14, 05:32 AM
P
Received 478 Votes on 439 Posts
A solvent welded trap is less likely to leak but it also can not be taken apart if you ever get a tough clog. Like Norm201 said. If it's not leaking I would leave it as is.
One suggestion if it is cosmetically acceptable is to not repair the ceiling to be totally smooth and finished. If the look is acceptable I would put up a removable access panel in case you ever need to work in that area again. Trim it with some molding and it can look pretty nice and professional.
HTML code is On
