warm /not cold?
Old 01-29-14, 07:01 PM
warm /not cold?
I was changing out a leaky line and shut off valve to toilet and had noticed afteri turned main line off that a bit of water continued coming thru on its own ,small stream..then i noticed it was luke warm..I then turned off supply at water heater and it stopped.are some toilets on the same line of hot supply or have a mixture valve in line ?
Any other possibilities i may need to adress ?
Its a 80s home and has copper.
Old 01-29-14, 07:16 PM
lawrosa's Avatar
Super Moderator
Received 10 Votes on 8 Posts
No its coming through one of the shower mixing valves most likely.. They are pressure balanced.
Just a siphon effect....
Old 01-29-14, 08:01 PM
Thanks for quick response..yea i thought somewhere they were mixing since it wasnt hot..
Does turning off the faucet,single valve, while still on hot side/delta/cause it to mix also?
Old 01-30-14, 04:08 AM
Received 194 Votes on 180 Posts
It's rare but some homes in the south have hot water plumbed to the toilets to prevent the tank from sweating. It's wasteful of energy but does work but I don't see the need since almost everyone has air conditioning these days. Still, I'd say Lawrosa's siphoning idea is more likely.
Old 02-02-14, 06:25 PM
Thanks for info..would that apply in Tn?
I do think it was just the mixing valve though.
HTML code is On
