pre plumbed basement questions
Old 02-05-14, 10:08 AM
I'm sure this has been posted before but I am in the beginning of finishing my basement and there is a bathroom. question one if I can see water in the bottom of the 1 1/2" line does that mean there is already a p trap? question two there is no stub out for a sink can I tie into the nearest vent line witch I'm pretty sure is for the toilet and bath?
Old 02-05-14, 10:57 AM
lawrosa's Avatar
Super Moderator
Hello and welcome to the forums....
Yes water in a pipe in floor should dictate a trap... But often it would be 2" if for a shower... For a tub the trap is left out and hooked up later...
Yes the sink line is always the vent in most circumstances...
But to be 100% sure of what you have there pictures would be best... Or some type of drawing...
Old 02-05-14, 11:37 AM
it is 1 1/2" pipe I checked the label and I can see water in the bottom there is enough room for a full bath. can I assume that I can cut this pipe down and put a T on to get to the drain and overflow?
Old 02-05-14, 01:25 PM
lawrosa's Avatar
Super Moderator
No.... If there is a trap then the waste and overflow fit right into this pipe... need to cut it down and add a trap adapter... That is if it lines up with the tub drain...
Old 02-05-14, 01:35 PM
it sits to far back to hit the drain and I'm not a plumber so whats a trap adapter
Old 02-05-14, 03:30 PM
lawrosa's Avatar
Super Moderator
The waste and overslow for the tub will look like this... The waste and oveflow tube should slip right into the 1 1/2 pipe...
Cut the pipe down some and add a trap adapter to the 1 1/2 pipe... Glues to the pipe...
If its off then you will need to dig down and add 45's to offset it some...
HTML code is On
