Adding main shutoff
Old 02-08-14, 03:26 PM
Y
Adding main shutoff
I had a pipe burst last weekend and tried to shutoff the main water supply, the CPVC main shutoff valve in the basement was so tight and I was so afraid it'd break.
Finally, I was able to turn it off and fixed the burst. I'm thinking to have a batter valve. The CPVC main shutoff valve is shown in the following photo.
shutoff | Flickr - Photo Sharing!
Can I adding a brass SharkBite ball valve above the CPVC valve and keep the CPVC valve?
Thanks for advices.
Old 02-08-14, 04:12 PM
Received 839 Votes on 786 Posts
Unless it's an easy job to get the water service turned off..... I'd leave that valve right where it is and add a new valve above it.
Old 02-08-14, 06:38 PM
Y
Thanks.
I could not find outside water meter and shutoff (it's remote meter) and I feel more comfortable to work after the original main shutoff.
Old 02-08-14, 06:43 PM
lawrosa's Avatar
Super Moderator
Received 55 Votes on 48 Posts
Hmmm if you have an outside meter then its easy to turn off as there is a shut off there..
Those PVC valves are worthless IMO..
I would remove the pvc from the copper female adapter, add a brass nipple, add a threaded 3/4" ball valve, and a pvc male adapter in the end of ball valve... Then glue back together...
No soldering needed....
Done!!!!!!
Old 02-09-14, 05:29 AM
Y
I completely agree that those CPVC valves are worthless. I can't believe codes allow them being use as main shutoffs. Some builders/plumbers tried to save few bucks, it could cost home owners 1000's of dollars of water damages. I still have 2 more CPVC shutoffs valves for master bath tub, one of them won't completely shutoff (see below).
CPVC | Flickr - Photo Sharing!
I agree replacing the CPVC main with brass ball valve will look more professional, I'll try to find the outside shutoff and necessary tools to turn it off.
Thanks
Old 03-05-14, 02:28 PM
Y
Last week, I called County Water and was told water meter was 10' from driveway, I found an old meter well with half cover 10' from driveway filled with soil (left).
I called County Water again, few hours later a truck came and a much larger meter well 5' from driveway was exposed (middle).
The next day the meter well was raised to above ground and I was able to open it and turn off water without special tools (right).
I was glad I called.
Old 03-05-14, 02:33 PM
Y
Followed advices from pros, I was able to replace the CPVC valve with a lead free full port brass ball valve. The floor of my basement was not even wet after it's done. I'm very happy with the results.
Thanks everyone!
HTML code is On
