bad toilet flange
I pulled my toilet up to replace the floor flange. The flange come up with the toilet bolts and all. It has a broken piece of the closet bend attached to it. Can I buy a closet bend? How do I install?
Received 1 Upvote
1 Post
If you can get underneath in a basement or crawlspace, you may be able to repair the broken line with a Fernco coupling, depending on where the break is in the line.
(Photo courtesy of atozplumbing-Plumber 2000)
You can get the coupling and all parts that you need at any plumbing supply or big box home store.
Screw the flange back down flush to the floor. Use new wax ring and toilet bolts.
Good Luck!
Good Luck!
