Bend in ABS drain pipe
Old 02-27-14, 03:09 AM
H
I need to make a slight bend (about 5 degrees) in my 3 inch ABS drain pipe. How should I do this?
Old 02-27-14, 04:13 AM
lawrosa's Avatar
Super Moderator
Received 55 Votes on 48 Posts
Depends on the length of pipe and/or what you are doing..Really not enough info.
If anything, two 45's will get you any angle you want...
Old 02-27-14, 06:54 AM
H
I need to get from the last fitting to the pipe from outside the house. The fitting (where the kitchen sink drains into the 3 inch drain pipe) is about five feet from the pipe it needs to connect to. If I connect a five foot piece of pipe to the fitting it will fall about 4 inches to the left of the pipe from outside of the house.
Am I allowed to use a flexible fitting on each end of the five foot piece?
I like the idea of a pair of 45 degree bends to deflect the pipe if it doesn't deflect more than the 4 inches. Perhaps a pair of 22-1/2 degree bends or a 22-12 degree bend and a 22-1/2 degree street bend might do the trick.
What do you recommend?
Old 02-27-14, 07:40 AM
lawrosa's Avatar
Super Moderator
No flex fittings........
Yes two 22's or what ever you need to offset it.. Street fittings may be best as they swing easier...
Old 03-01-14, 03:02 AM
H
Done
A pair of 1/16 bend (22-1/2 degree) elbows did the trick. Thanks for the help.
HTML code is On
