rough plumbing / venting Q
Old 03-02-14, 03:40 PM
Hello,
I am building a new bathroom in the basement. Question is I will be putting in a neo angle shower and a sink. Can or should I share the venting for both the shower and sink ? or should each have its own ? and tie them together later. I'm think running a vent from T straight up from the sink drain would be redundant. I will attach a rough sketch.
Thanks
Old 03-02-14, 05:21 PM
lawrosa's Avatar
Super Moderator
Received 55 Votes on 48 Posts
Hello and welcome. You can delete the shared vent. Its not needed.....
Old 03-03-14, 12:13 PM
Could I eliminate the vent running up from the sink and just use the shared vent ?
Old 03-03-14, 12:15 PM
lawrosa's Avatar
Super Moderator
how many ft from the trap will the shared vent be? I think its like 8 ft max.. Need to check code...
Codes are in a sticky at the top of this thread...
HTML code is On
