Securing PEX to Wood ?
Old 03-05-14, 10:40 PM
Hello,
A plumber put a 20' run of PEX that had been supported by some wood cross beams that were recently removed. I now need to secure this pipe and wanted to know whether it's appropriate to secure PEX to wood using a copper van hanger? Given the location of the pipe and the wood, this should work well. Is there any issue with using a copper plated clamp with PEX? Thanks in advance.
Old 03-06-14, 03:08 AM
chandler's Avatar
Received 2 Votes on 2 Posts
Welcome to the forums. Use Sharkbite talon clips. Made for this application. I would not use a metal strap. SharkBite 1/2 in. x 3/4 in. Plastic Talon Clamps (10-Pack)-23220 at The Home Depot
Old 03-06-14, 04:39 AM
Norm201's Avatar
Received 64 Votes on 59 Posts
Why not? I'm assuming there is no movement of the pex along the metal.
Old 03-06-14, 05:21 AM
Received 200 Votes on 185 Posts
PEX expands and contracts greatly as it's temperature changes. This movement over metal will eventually cut through PEX. Trust me, I learned that one the hard way. The plastic hangers designed for PEX are very inexpensive and easy to use so there's really no excuse not to.
Old 03-06-14, 08:12 AM
Thank you for the reply. I saw those, I need something I can screw into the wood as there is really no room to hammer anything. It's a very tight space and there is copper pipe that's in close proximity. Are there are other styles of PEX clamps.
Would this work? It has rubber: http://www.elecdirect.com/images/pag...ableClamps.jpg
Old 03-06-14, 08:56 AM
Yes, you can use those clamps or you can pull the nail out of the plastic PEX clamps and replace with a screw.
Old 03-06-14, 09:34 AM
lawrosa's Avatar
Super Moderator
Received 14 Votes on 12 Posts
Old 03-06-14, 10:01 AM
Thanks Everyone. Appreciate it
Old 03-07-14, 02:43 AM
I think I missed something ? Hot Water or Cold Water ? I have never used PEX . Is it approved for HW ?
If for HW , are you going to insulate it ? If so , get a large enough strap / clamp to accomidate the insulation .
I have been using
Plastic Hanger Strap | Pipe Support | Oatey
to hang my new HW lines + the insulation . And an appropriate screw for the floor joists .
God bless
Wyr
Old 03-07-14, 03:33 AM
chandler's Avatar
Yes Pex is good for both hot and cold water. Much easier to use than copper, cpvc, or other traditional materials. Insulating the Pex would require a different clamp, and what you show is viable.
Old 03-08-14, 01:57 AM
Thanks , I will remember that . Is there a different " color " PEX for HW or is it the same as for CW ?
If it is like the old Quest pipe , the price of the fittings is where they " got you " ? I think they took it off the market ?
I have been using copper for my project .
God bless
Wyr
Old 03-08-14, 04:06 AM
chandler's Avatar
Pex comes on opaque white, red (hot) and blue (cold). Totally different from polybutelyne, or Quest.
Old 03-09-14, 03:08 AM
Thanks , :-)
God bless
Wyr
HTML code is On
