pex fitting
Old 03-12-14, 06:08 PM
D
pex fitting
can I get a 1/2 pex to 3/8 flex line threaded female in a 1 piece brass fitting at Home Depot??
Old 03-12-14, 09:37 PM
If your talking about a 1/2 Pex to 3/8 compression then yes they should have them.
Old 03-13-14, 03:32 AM
chandler's Avatar
Received 4 Votes on 4 Posts
If they don't have it in pex, I know they have it in sharkbite.
Old 03-13-14, 06:41 PM
D
I mistakenly bought a pex fitting that is 1/2 pex to the LARGE end of a standard 20 inch
flex line.After I crimped the pex I was left with the small end and the standard sink fitting wants the large end.
I have some odds and ends..If I jerry rig some other stuff together...can I teflon tape some connections on flex line to seal them
or no?? otherwise I need new ones.Some people say no tape on those flex lines....these are older fittings.
Is there a 1/2 pex to the SMALL end of a standard 3/8 flex line?? I didnt see one at HD but wasnt looking too hard for that.
Another thing....my red and blue PEX says on the side 1/2 and 5/8 on it...??
When I put the 1/2 pex connector in it was loose.It did crimp ok. I have some spare white PEX 1/2 inch and I tried the fit on it and it was tighter...??????
thanks for the info....
HTML code is On
