Bathroom shutoff valve
Old 03-15-14, 07:19 PM
G
Hello,
I'm replacing my bathroom faucet. My shut off valve output hose is a pipe. Should I remove the bolt and replace with flex piping? My valves are older and I'm wondering if I should replace as well. Would it be easy as a cutting the pipe and Soldering a new valve on? Thank you in advance
Old 03-15-14, 07:23 PM
lawrosa's Avatar
Super Moderator
Received 55 Votes on 48 Posts
Replacing with a flex line will be easiest since the rigid supply's uses a ferrule......And usually are not reused...
Why change the valve if its not causing issues?
Welcome to the forums...
Old 03-16-14, 05:13 AM
Norm201's Avatar
Received 174 Votes on 158 Posts
If that valve has not been turned in a long while, you may find that it will leak through the stem or not shut of altogether. If it was me, I would replace the valves with new 1/4 turns. Now is the time to do it while you're replacing with a new faucet.
BTW...Use the stainless steel flex supply lines, not those plastic reinforced ones.
<input id="mac_address" value="" type="hidden">
HTML code is On
