Shut-off install - rookie question
Old 03-20-14, 10:56 PM
I am looking to install a new gas range, and a shutoff in the process. Is it as simple as removing the flex line and putting on the shutoff? The bottom piece does have the curb-stop lookin shutoff on the back. Does that help my process?
Will increasing the height be a problem? I also see that the thread tape is white. Itís not currently leaking, so do I apply 'It ainít broke'?
Oh, and please disregard the wallpaper - its hidden behind the stove
Old 03-21-14, 04:46 AM
Norm201's Avatar
Received 58 Votes on 56 Posts
If that back piece near the wall is in fact a shutoff and it works then another shutoff is not necessary. Typically when you replace a range you also replace the flex tube. At this point if the TFE tape is not leaking leave it alone, but when putting on new fittings use the yellow stuff.
HTML code is On
