need help with codes in nyc and shock absorbers or air chambers
Old 03-22-14, 08:00 PM
i recently did my 2nd floor over and added 2 baths and washer dryer. my question is do i have to install those shock absorbers or air chambers ? i was told that it is code and then i was told its not. i am going to install in the cold & hot water on washer machine and maybe each toilet . which is the best to go with ?
Old 03-23-14, 03:54 AM
chandler's Avatar
Welcome to the forums. Can't help you with NYC codes, but hammer arresters are a good investment. Installing one each on the hot and cold of the washer should suffice. You could check with your local permit office to see if they are required.
HTML code is On
