What is Causing Nozzle on Outdoor Spigot to have Low Pressure?
Old 05-25-14, 11:38 AM
U
Hi. I am trying to figure out why the nozzle connected to a garden hose on an outdoor spigot has such low pressure. I tested the water pressure with a gauge connected to the spigot and it read between 50 and 60. The hose is only a couple of years old, and I bring it into the garage during the winter. The nozzle is only a couple of years old, and I had the low pressure with another nozzle too. I dont see any leaks. The valve is completely open on the outside and the shutoff valve on the inside of the house is completely open too. I replaced the sillcock two summers ago, it has a vacuum breaker as part of the sillcock. I don't see leaks at the breaker.
So what could be causing this problem?
Old 05-25-14, 08:24 PM
F
Received 34 Votes on 26 Posts
You state you have low pressure from a nozzle on the end of the hose, do you REALLY mean you have a low flow rate? What is the length and inside diameter of the hose? What is the size of the piping supplying the water to the faucet and what type of valves are installed?
Old 05-26-14, 05:11 AM
P
Received 486 Votes on 447 Posts
Have you tried the hose without the sprayer nozzle on the end? If you have good flow at the end of the hose your spray nozzle is probably clogged with debris and needs to be cleaned out.
Old 05-26-14, 07:12 AM
jmnew51's Avatar
Or better yet just unscrew the hose from the spigot and try that.
Jim
Old 05-26-14, 06:15 PM
Z
Received 84 Votes on 79 Posts
Try timing how long it takes to fill up a 5 gallon bucket straight from the spigot, then again from the end of the hose. They should be somewhat close.
50-60psi is pretty standard for a residence, so you're good there.
HTML code is On
