Extending the washing m/c drain pipe
Old 05-28-14, 12:50 PM
C
I want move my washer to attic ( A -> B ) and connect new condensate water pipe from thankless water heater. i would like to know weather i can add T joint to ( C ) position and connect to attic ( D ) and the other end use for condensate water from heater. appreciate any other suggestions also.
Old 05-29-14, 11:03 AM
Z
Received 128 Votes on 119 Posts
You can't have the washing machine trap on a different floor from the appliance. So you'll have to add a new drain for the washer.
You have that 1.5" pipe marked as a vent, is there anything else draining into it other than the washer? Where does it go as it goes down?
Also, code now requires a 2" drain pipe for washing machines since the HE models tend to push a lot of water out quickly.
Old 05-30-14, 03:05 PM
C
thank you so much for the info . the pipe goes under the slab ( drain ) line and kitchen sink connection is next to current washing m/c drain connection ( 3" inch from the T )
thanks
chan
HTML code is On
