Anti Frost Faucet - to insulate or not?
I just replaced an anti frost faucetthat has failed because the hose was left connected and undrained during a cold spell.
The faucet comes into the basement and my normal tendency would be to insulate it for a ways until past the point of entry. After thinking about it that could possibly have the opposite effect - inhibit the warmer air from the basement to prevent freezing while allowing the cold air to conduct more efficiently from the outside.
What is the proper method?
Thanks,
David
Thanks,
David
There's no reason to insulate a freeze-proof or anti-frost faucet if installed correctly. All water will be behind the washer and seat, which should be in the conditioned (or semi-conditioned) space.
The problem was that a hose was connected that didn't allow water beyond the seal to drain out.
If the penetration through the wall is properly caulked/foamed, then all that will cool the sealed area is conduction, which you can't do a lot about.
You can use one of the foam and plastic insulated faucet covers available, that is easy and cheap.
Standard Faucet Cover-1950 at The Home Depot
They also make them with a brownish red plastic shell which get the max heating from the sun on clear cold days.
To add, make sure you install the nylon wedge provided at the top of the flange. This will intentionally point the faucet downward allowing the water to evacuate.
